Cisco Click to call
julienf28
This little widget is a great tool with our new VoIP UCM 7.0 except for one thing. I can't get it to work with Outlook 2007. It works fine in IE, Excel and Word. I just right click on the number and place a call.
If I go to the contact name in Outlook and right click on the number then go to call Contact... it uses the default Outlook protocol to place the call and not Click to call.
guy.richard
This is caused by a little bug .
Are you using C2C in outlook with another user that the one used for install ?
If it's the case you can obtain from the TAC (it's not yet published on CCO) a new version for C2C it also fix the bug usint C2C in Firefox.
"CSCsx17963 - No 'Additional Actions' on Outlook if C2C installed by another user.
You can also review the defect on our Bug toolkit link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCsx17963"
Guy
guy.richard
Guy
Thanks Guy, this identifies an issue we have been trying to fix for weeks
Cisco TAC are posting an ES release C2C 7.0.13 so hopefully this will resolve my issue
