ospf cost
Answered Question
Jun 30th, 2009
How does traffic form source A going to destination E will be routed if ospf cost on all links are equal. Thanks
Correct Answer by Edison Ortiz about 7 years 8 months ago
It will try to load balance the traffic but it relies on CEF load balancing, so traffic is not actually equally balance across the links.
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
Overall Rating: 5 (2 ratings)
John Blakley Tue, 06/30/2009 - 12:39
  • Purple, 4500 points or more
If all costs (metrics) are equal, it will do equal-cost load balancing. Both routes (A-B-E and A-C-E) will show up in the routing table at the same time.
HTH,
John
cisco steps Tue, 06/30/2009 - 13:14
that is what I am trying to figure out...so 1/2 on one side and 1/2 on the other ? if yes how does the packet get reassembled at the destination.
cisco steps Tue, 06/30/2009 - 14:58
that is the answer that I was looking for.. Thanks a lot..
If route-cache mechanisms are disabled, the route table is the only information used to forward a packet. For every packet the destination address is matched against the route table, and the packet is forwarded through the interface with the lower utilization.
