WCS Report - Rogues on Wired LAN
Jun 30th, 2009
Each WLC on our network shows "Rogues on Wired Network" from the Summary screen, however, checking these can be time consuming due to the number of WLC's in the network.
All of the WLC's are connected to a WCS so I was wondering whether a report for "Rogues on Wired Network" is available on the WCS??
I've spent a while looking around the WCS but can't find this information.
Any help that would make checking this easier greatfully recevied...
Lucien Avramov Fri, 07/03/2009 - 18:28
there is the switchport trace feature in WCS 6.0 that enables you to find on what switchport is connected the rogue ap. That is the way to find wireless rogues on the wired network
BlueyVIII Mon, 07/06/2009 - 05:22
Thanks. Unfortunately I only have WCS 4.1.
Is there a way to trace the rogues using this version?
Lucien Avramov Mon, 07/06/2009 - 20:32
Unfortunately no. The feature works quite well only since WCS 6.0.
If you have a WCS 4.1 you may be able to update to 5.2 or 6.0 as licensing should be the same. Check with your sales team.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
