LWAPP AP over Cellular
reginald-pugh
What is the requirement for having an LWAPP ap join a controller over broadband cellular network i.e EVDO or HSDPA?
Has anyone been successful with this?
Something for consideration:
I would love to see Cisco push a lite version of code with the CWAP or LWAPP capability to the new Verizon /Sprint MiFi device for road travelers.
http://www.novatelwireless.com/index.php?option=com_content&view=category&layout=blog&id=75&Itemid=622
I believe the magic number you are looking for is 300ms
10 Replies 10
Hi leolahoo,
Yes. Could you use OfficeExtend over a broadband cellular connection ? Coud you use lwapp ap on a regular (4402/2204 anchor controller in the DMZ ?
Hi Reginald,
I have some baaaaad news for you. OfficeExtend is only for the new 5508 WLC and it is not backward compatible.
OK, what kind of bandwidth is needed to maintain the connection for the AP to the 5508? Can you join those the 1130 and 1140 APs to it (5508) over a home broadband cellular router?
Thanks for the help.
Leo Laohoo
I have not yet heard or read of anyone implementing this solution so I would not be able to inform you of the bandwidth requirements of OfficeExtend.
Here are some documents about configuring OfficeExtend:
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60lwap.html#wp1502346
thanks leolahoo, 5 points at ya for the link to how office connect works,
I found something of value on this latency issue, just need to understand Cisco' position (Best Practices) on using a broadband cellular ISP as the path for WAN connection from the remote home office.
Configuring Link Latency
You can configure link latency on the controller to measure the link between an access point and the controller. This feature can be used with all access points joined to the controller but is especially useful for hybrid-REAP and OfficeExtend access points, for which the link could be a slow or unreliable WAN connection.
Hi ericgarnel: where can that be found in Cisco documentation or is this ased on tests with other wlan systems?
Reg
The 300ms number can be found at http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080736123.shtml#t8
Keep in mind you really want to keep it as low as possible for authentication and roaming etc.
Leo Laohoo
Thanks for the ratings Reginald.
