ip policy route-map command is not working
Answered Question
Jun 30th, 2009
I tried to apply the ip policy route-map command to an interface vlan X, but is not working.
The IOS version is:c3560-advipservicesk9-mz.122-25.SEE4.bin
I searched on Cisco and it looks like PBR is supported in this IOS.
The show ip interface vlan X command shows policy routing is disabled and there is no access-list set.
So, PBR is not working. There are no packet matches against route-maps.
Thanks all.
Correct Answer by Edison Ortiz about 7 years 8 months ago
Make sure you have the 'dual-ipv4-and-ipv6 routing' template applied on the switch. The default template is desktop which does not support PBR.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_see/configuration/guide/swsdm.html
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
petero007 Tue, 06/30/2009 - 21:40
Hi Edison,
I applied the "desktop routing" template because i no need IPV6 support, and then, PBR works fine.
Thanks for all.
