Can't dial from Corporate Directory number contains +
Answered Question
Jun 30th, 2009
I need help.
I can not dial from the Corporate Directory when the number is containing "+" as the prefix
for ex :
+659100xxxx
i created a translation rule but it only works if i dial directly 65910xxxx from the phone.
Anyone can help to solve this ?
Using CUCM 6.1 and AD
David
Correct Answer by Jonathan Schulenberg about 7 years 7 months ago
The translation pattern will interrupt the plus (+) character as a regular expression character if you do not escape it.
For the translation pattern to match, you must type \+659100xxxx
Overall Rating: 5 (1 ratings)
metuzuner Wed, 07/01/2009 - 04:02
Hi David, I tried to reproduce this problem on our 6.1 Environment, but not having the same issue even if the number contains a '+' as a prefix. Calls go through normally; and there is no translation pattern for it in our system.
dsuntama@netabi... Wed, 07/01/2009 - 18:23
Is there any parameter that should be changed ?
1. on our lab using CUCM 6.1 and it works with "+"
2. on our client using CUCM 6.1 but it doesn't work with "+"
3. on our productive using CUCM 7.1 but it doesn't work with "+"
pls help
thanks
Correct Answer
Jonathan Schulenberg Thu, 07/02/2009 - 06:08
dsuntama@netabi... Sun, 07/19/2009 - 18:41
I found something strange.
In our lab and productive environment, it works by adding \+
however at one of our client using CCM 6.1 when I try to add \+ on the translation pattern, it says warning error.
I can't remember excatly the message.. seem that
"Translation pattern only can contains character .[!/ ,etc"
Any clue for this ?
Thanks in advance
Jaime Valencia Sun, 07/19/2009 - 19:32
I'm not even sure how you mention you were able to add it on a previous post. \ is not a valid character as noticed and also guides do not show it.
Wildcards and Special Characters in Route Patterns and Hunt Pilots
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmsys/a03rp.html#wpxref11697
Compare the exact versions you're running.
java
if this helps, please rate
