constant High CPU on 3550 and 3750 switches due to vlan 1
Jul 1st, 2009
We are experiencing constant High CPU on 3750 switches due to vlan 1
Further info - we have a pair of Alteon load balances between the 3500 and 3750's which is also running vlan 1. Could this produce high CPU ? (Appreciate vlan 1 usage not best practice but ignore that for now). We run sho proc cpu sorted and see vlan manager proc running cpu at 90% constantly. How would vlan ID manger process push cpu to 90% and hold it there ? - appreciate any ideas on this.
Jerry Ye Wed, 07/01/2009 - 06:28
Hi David,
The problem you are discribing sound like a spanning tree loop.
Just a question, how is the switch port configuration for the Alteon? If they have spanning portfast enabled, turn it off and make the switch to run its spanning-tree algorithm to see this will improve. Also, you should schedule a maintenance window to test this configuration.
Leo Laohoo Wed, 07/01/2009 - 14:48
I agree with Jerry. Had experience with this and most of the time it boils down to spanning-tree portfast enabled to uplinks like switches.
This could be caused by someone (other than the IT department) bringing to work a number of un-managed switch or hub (oh no!) and connecting them around their respective desks.
Also, try to steer away from using VLAN 1.
Hope this helps.
