Mutilple VPN connections from one public IP
Jul 1st, 2009
We have an ASA5510 set for VPN connections. We have 3 clients that will simultaneously connect to our VPN using one Public IP since they are located in one office. I have observed that only one connection are able to successfully connect. Is there a way to allow multiple connection from a single public IP?
Hope someone will reply. Thanks.
Overall Rating: 5 (1 ratings)
Todd Pula Wed, 07/01/2009 - 10:31
  • Silver, 250 points or more
You will want to make sure that the ASA is configured to support NAT-T. To enable NAT-T, you will issue the following command: crypto isakmp nat-traversal 10. Please test with this command in place and report back.
helios999 Wed, 07/01/2009 - 17:07
Hi topula, thanks for the reply. I will test it now then I will give you feedback. Can you please kindly tell me what this command do?
helios999 Thu, 07/02/2009 - 23:03
Hi topula, your suggestion solved my problem. Thanks for the help. I will rate your help accordingly.
