Xmedius Fax Server Integration
Jul 1st, 2009
I am in the process of integrating the Xmedius fax server and cannot seem to get the server to communicate with the call manager. We are running CCM 4.2.3 and i have followe the Xmedius install guide. The Xmedius installer technicians cant figure it out either. The fax server wont send a fax or answer an inbound fax call. We have configured it as MGCP and the fax server is setup in call manager as an H.323 gateway. Any assistance would be greatly apreciated.
kinwai Wed, 07/01/2009 - 10:26
i got the following config working before but it's for h323
dial-peer voice 301 voip
description FAX Dial-Peer
destination-pattern 6431....
session target ipv4:10.205.x.x
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
you might want to try it out
cisco_lex Thu, 07/02/2009 - 09:11
If the fax server works as an MGCP gateway, why are you trying to register it on CCM as an H.323 device? Looks like CCM and XMedius speak different protocols to each other.
jkjackson Thu, 07/02/2009 - 09:14
The resolution was seting the mgcp fxr-package as default. I had done this but when i reloaded the gateway the setting didnt keep. must not have wrote i to memory. Any ways, its working now.
