Call Manager 4.1(3) VM port status "NOT FOUND"
twfredericks
Hi All -
I am running Call Manager 4.1(3) and Unity Connection 1.2(1) and have 24 VM ports. Three of the 24 ports (port 6, 14, 19) have a status of "NOT FOUND". No matter what I do I can't get them to register. I have tried resetting the ports in both Call Manager and Unity Connection. Does anyone have any ideas? Thanks for the help!!
Does port names matching on both Unity and CM? Check it carefully as small mistake can leads to problem.
The port names in both Unity and CM are matching. These ports have been registered before and nothing has been changed.
That usually is caused by ports locking up in the VM, i'd suggest a CUC reboot.
java
if this helps, please rate
java
A CUC reboot did fix the problem. Thanks for the advice.
