Question for achieve Call queue on call manager business edtion
Jaime Valencia Wed, 07/01/2009 - 08:24
  • Cisco Employee,
  • Hall of Fame,
    2011
In CUCM only with broadcast setting in AC.
In CUC by using a supervised transfer to a DN so it loops and asks you whether you want to wait or to leave a message.
java
if this helps, please rate
Rob Huffman Wed, 07/01/2009 - 08:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Tony,
It sounds like the AC Broadcast Hunting method might be a nice fit because it really approximates some standard Call Centre functions. The ability to Queue up callers and play either Music or some sort of "Hold in Queue" messaging as well as Login/Logout for the staff is great.You can use the setting for the "Always Route Member" to route calls to VM after a specified time or if too many calls are holding. This Voicemail can be setup on the Pilot Point number so that it doesn't hit the users Personal mailbox. Have a look;
**Broadcast Hunting - When a call arrives at the pilot point, Cisco TCD answers the call, places the call on hold, adds the call to the queue, and displays the call in the Broadcast Calls window on attendant PCs. While on hold, the caller receives music on hold, if it is configured. Any attendant can answer the call from the Broadcast Calls window. You can choose this option from the Attendant Console Configuration tool.
Understanding Broadcast Hunting
Broadcast hunting enables Cisco Cisco CallManager Attendant Console to answer calls and place them into a queue. The attendant console displays the queued calls to all available attendants after inserting the calls into the queue and to all attendants that become available while the call is in the queue.
Note The attendant console only broadcasts calls to attendants that are set up as user/line number hunt group members in the broadcast hunting pilot point.
The queued calls appear in the Broadcast Calls window on the attendant PC.
Any attendant in the hunt group that is online can answer the queued calls. Cisco CallManager Attendant Console does not automatically send the calls to an attendant.
You can specify the following values for each broadcast hunting pilot point:
Queue Size - This field specifies the number of calls that are allowed in the queue. If the queue is full, Cisco CallManager Attendant Console routes calls to the "always route" hunt group member that i s specified on the Hunt Group Configuration window. If you do not specify an always route member, Cisco CallManager Attendant Console drops the call when the queue size limit is reached.
Hold Time - This field specifies the maximum time (in seconds) that Cisco CallManager Attendant Console keeps a call in the queue. If the call is in the queue for longer than the "HoldTime," the call gets redirected to the "AlwaysRoute" member. If you do not configure an always route member, the call remains in the queue until an attendant becomes available.
When a call comes into a pilot point, Cisco TCD uses the hunt group list and the selected call routing method for that pilot point to determine the call destination. During hunt group configuration, you must specify one of the following options for each hunt group member:
Directory number (device member)
If a directory number is specified, Cisco TCD only checks whether the line is available (not busy) before routing the call.
**Attendant console user plus a line number (user member)
If a user and line number are specified, Cisco TCD confirms the following details before routing the call:
**That the user is logged in to the attendant console
**That the user is online
**That the line is available
Hope this helps!
Rob
Edit: Java, you are too skilled for my "hapless" typing ability :) Cheers! Huff
