CLI Postview
jaydien1358
Level 3
Level 3
Why does CCA always show the same information for my CLI postview?
In SDM, it shows the actual CLI commands. Is this possible with CCA?
-Brian
16 Replies 16
Steven Smith
Level 7
Level 7
In CCA...
System -> Preferences -> Advanced
Can you make sure that Enable CLI postview of IOS voice features is checked?
Yes it is.
-Brian
CCA 2.0?  What are you changing when nothing shows up?
Yes CCA 2.0. I've been working on BACD configuration. Does that not have any CLI code to show?
-Brian
Brian,
Please unicast Tomoo Esaka at tesaka@cisco.com for CCA 2.0.1.   You will not be happy with CCA 2.0 in this regard.   CCA 2.0.1 will address all the issues I am afraid you may find, part of which is associated with the version of TCL scripts.  You need 3.0.0.2.  CCA 2.0.1 will take care of that for you.....
Steve
Steve,
Do you have a release date for 2.0.1???
Eivind
Posted yesterday!!!!!    Hurray!!!!!!!!!!!!!!
I have installed the latest version of CCA; 2.0.1. However it has still not resolved my issue with the CLI postview. Please advise.
Thanks.
-Brian
www.jaydien.com
Brian,
Please verify that the following CLI is on your system:
archive
log config
  hidekeys
Let us know if this fixes the problem. Thanks,
Marcos
Marcos,
Yes I do have that CLI on my system:
archive
log config
  hidekeys
-Brian
I also just reinstalled CCA 2.0.1 and that did not help.
-Brian
Is this happening with BACD only?  Or all COnfigurations?
Steve
This is happening with all configurations.
-Brian
Brian, under "archive" can you do "logging enable"?
Marcos
