CVP Voice Browser is out of service.
I would think so. What image have you?
On a 2811 you can certainly get an IOS image like that - I've done this a number of times.
So I assume the 2801 will also support it, but I cannot be absolutely certain without searching the IOS feature list on Cisco.
Does your current image support the "gatekeeper" command?
fabien.damien Mon, 10/26/2009 - 00:48
Hi Geoff,
i have the same problem as Manich, although the gatekeeper is showing up.
entered the command set Gatekeeper (where is the ip of the gatekeeper and CVP_LAB the zone name)
the gateway and the gatekeeper are both installed on the same router and the former is registered with the latter.
this is a lab installation, do we need a license for the h323 to go in service?
can you please advise?
