7835 IPCC Express Queue Limit, 7845 Hardware Upgrade?
Jul 1st, 2009
Curently we have a two MCS-7835 (HA) Servers Running IPCC Express 4.0(5) which limits us to 25 queues. We have recieved 2 MCS-7845 Servers that we would like to install to allow us to build the 75 queues that we now need. The question is if we follow the hardware replacement proceedure, and do the restore from BARS to these new and different 7845 servers, will we still be limited to 25 queues by something in the restore process or would that increase.
Dennis Aston Thu, 07/02/2009 - 16:26
Just a guess so take it for what its worth until somebody can provide you with an absolute. I would think that your limit is detected/enforced by the product installed on the server, IE UCCX 4.0(5) in this case. If you want a firm answer though I would start a TAC case, they can nail it down for you.
I could be wrong but I wouldn't think this would be something that would be restored in a BARS restore. Have you looked to make sure its not a licensing thing?
dyanuszeski Fri, 07/03/2009 - 09:04
Thanks for the reply,, I did open a TAC case yesterday, but the reply I got back just said that the new 7845 will support 150 Queues, and that it should work after the restore, but with no specifics as to why it should. I don't think that the licensing is the limitation, and in the 7835 will currently allow you to build more that 25 queues, but they just will not come active.
