Site-to-site VPN over ADSL
Jul 1st, 2009
I'm planning to setup a site-to-site VPN between 2 offices with 2xASA5505. All we need is file sharing - no apps will be running on it.
Both offices use ADSL connection. Is site-to-site VPN going to work over ADSL or we need to get an upgrade to something more stable?
Thank you.
Overall Rating: 4.3 (3 ratings)
Richard Burts Wed, 07/01/2009 - 17:48
I do not see any reason why a site to site VPN would not work over ADSL. The ASA5505 would seem to be a good choice for implementing this.
In a site to site VPN each side generally uses a unique IP subnet on its LAN and you route between them over the VPN. Is this what you are planning?
oleg.slivnyak Thu, 07/02/2009 - 08:08
Yes, that's pretty much what we're planning to do. My concern was that with frequent connection drops and generally unreliable service in ADSL, VPN tunnel will need to be re-established manually.
Leo Laohoo Thu, 07/02/2009 - 15:44
Hi Oleg,
I'm not familiar with the different products and services of your country. But I do know for a fact that in Australia, "internet-grade" ADSL and SLA DO NOT MIX. Businesses are encouraged to opt for "business-grade" DSL (called BDSL). This is more expensive than the former but cheaper than dedicated line.
Hope this helps.
thotsaphon Fri, 07/03/2009 - 02:06
ADSL is not stable as you mentioned. However the tunnel would be automatically built as long as interesting traffic has been passed through the ASA. To make sure that you enable "keepalive" on both side to check the peer status.
