How to configure AS5400 for signaling mode with PGW2200
Jul 1st, 2009
we are currently using PGW2200 in call mode that is sip call are handled by
PGW2200 & AS5400 is connected to PSTN via E1 i need to know can i directly terminate H.323 csll on gatways as PGW2200 will be connectes to PSTN using ss7 . what config need to be done,
tstanik Tue, 07/07/2009 - 10:03
The Cisco PGW 2200 is designed to provide maximum support for different IP network architectures. This flexibility helps enable the Cisco PGW 2200 to provide an SS7 interconnect for H.323- or SIP-based networks where the call control resides in the Cisco AS5000 Voice Gateways (signaling mode), or it can provide intelligent call control and routing functions for MGCP-based voice gateways (call control mode) while concurrently providing an H.323 or SIP interface for maximum flexibility and interoperability.
The following PSTN gateway applications are enabled by the Cisco PGW 2200:
Voice-over-IP (VoIP) transit
Primary Rate Interface (PRI) Grooming and Time-Division Multiplexing (TDM) Offload
SIP PSTN gateway
H.323 PSTN gateway
Enterprise Services (Hosted Voice and Call Center)
