how to enable CMRs
Answered Question
Jul 1st, 2009
hi, i've already enabled the CDRs, and they are comming fine to the sftp server, but i dont see the CMRs, what else do i need?
Correct Answer by Jaime Valencia about 7 years 11 months ago
You mention you enabled CDR, but did you enabled CMRs??
Enabling CDR does not enable automatically CMR.
You need to change the Call Diagnostics Enabled parameter to TRUE to get CMRs.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 07/01/2009 - 15:38
  • Cisco Employee,
  • Hall of Fame,
    2011
java
