restore ACS v3.2 backup on an ACS v4.2 or v5.0
Jul 1st, 2009
Hi to all,
Does anyone know if it is possible to restore an ACS v3.2 backup on a new ACS v4.2 or v5.0??
I have a customer that wants to perform an upgrade but i'm not sure if we will have to configure all over again in the new version.
Thanks in advance for your help.
Jagdeep Gambhir Fri, 07/03/2009 - 06:07
Yes, it can be restored up to 4.2. Here is the upgrade path,
5.0 is not windows based so you cannot upgrade it to 5.0
Do rate helpful posts
alfonso.cornejo Fri, 07/03/2009 - 07:22
Hi jgambir,
Is there a special procedure to restore between different versions or we just have to follow the regular procedure??
Thanks alot for your help.
alfonso.cornejo Fri, 07/03/2009 - 07:30
Hi jgambhir,
I'm sorry, i misunderstood...i have to upgrade the version of the ACS right? ...using the path that you gave me
