Leo Laohoo Wed, 07/01/2009 - 17:11
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Route ALL networks.
matcor9925FDS Wed, 07/01/2009 - 17:13
If I'm understanding correctly, All connected networks will participate in the configured EIGRP AS?
Richard Burts Wed, 07/01/2009 - 17:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Matt
Yes if you configure network 0.0.0.0 under router eigrp then eigrp will include every interface that is up/up in the routing protocol, will send Hello messages through each interface and will attempt to establish eigrp neighbors on each interface. eigrp will also advertise the subnet found on each of the interfaces.
Rick
matcor9925FDS Thu, 07/02/2009 - 05:57
Thanks to both of you. This helps a lot. Is there anywhere on cisco's site where this is documented? I could not find it. Thanks again.
lordsporkton Thu, 07/02/2009 - 08:45
I have never seen direct documentation on using 0.0.0.0 however there is certainly documention on how the network command works under eigrp, which is that it will listen on any interface which falls with an ip address inside the network command.
So if your network command covers every network then any interface would be covered
