How to repeat a hunt list
Jul 1st, 2009
Hi guys,I have a hunt pilot with 5 members, how can I repeat the hunting if all members no answer or busy until Maximum Hunt Timer timeout. it seems each member only hunted once by default
My CCM version is 4.1
Overall Rating: 4 (2 ratings)
gogasca Wed, 07/01/2009 - 21:37
  • Green, 3000 points or more
try duplicating the line group with different name same members.
Rob Huffman Thu, 07/02/2009 - 02:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Peng,
You can however set up a second Line Group that contains the same DN's/Members and link this second Group in the Hunt List.
Switch the rule on the first Line Group to, Try next Member;then try next Group in Hunt List
This will then cycle through the members a second time (I just tested this out in our lab) :)
Hope this helps!
Rob
pengfang Thu, 07/02/2009 - 08:46
Thanks Rob and GONZALO, the duplicated line group works.it's nice to have a option to seltect "repeat" and "repeat times".
