vlan 1 interface for NM-16ESW
Jul 1st, 2009
NM-16ESW modules into 3700 creates an vlan 1 interface.IS this the mangement interface for switching module
or what is the purpose of assigning ip address to this vlan 1.
Leo Laohoo Wed, 07/01/2009 - 21:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
IP Address for VLANs are purely for management purposes only. You can, if you like, leave VLANs with no IP Address but what do you do when you need to configure the switch?
Hope this helps.
Richard Burts Wed, 07/01/2009 - 21:53
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Muhammad
Leo's response is oriented more to a standalone layer 2 switch. Whether it is appropriate in your case depends on whether you leave the ports in the switch module in the default of VLAN 1 or whether you assign the switch ports to other VLANs. As long as the ports in the switch module are in VLAN 1 then they need a layer 3 interface to provide routing for the subnet to which they all belong. And the interface vlan 1 with its IP address is providing the routing for that subnet. So its function is more than just management of the switch.
Rick
seekhpar121 Wed, 07/01/2009 - 23:04
Thanks for reply,
Following is the configuration of Switching module in router.
interface FastEthernet1/0
switchport access vlan 5
switchport mode trunk
interface FastEthernet1/1
no switchport
ip address 10.1.1.1 255.255.255.0
interface FastEthernet1/2
no switchport
ip address 10.2.2.1 255.255.255.0
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface Vlan1
ip address 202.X.X.X 255.255.255.0
interface Vlan5
no ip address
router ospf 1
network 202.x.x.x 0.0.0.255 area 0
Can someone elaborate the above configuration including the purpose of ip address of vlan 1.
