Multiple gateway on the same network with VPN
Jul 2nd, 2009
Dear all,
i have problem of multiple gateway with VPN, please refer to the attached pics:
PC B cannot ping PC A if PC A's gateway is not pointing to the VPN Router
if i change the PC A default gateway to 192.168.1.2 ( VPN router) , then PC B can ping it. but the fact is we have to keep the default gateway stick to 192.168.1.1 . is the any way to make it happen ?
Thx
mvsheik123 Thu, 07/02/2009 - 12:13
  • Gold, 750 points or more
Can you add static route on Linksys router 'ip route 192.168.2.0 255.255.255.0 192.168.1.2' and give a try..?
hth
MS
**Rate helpful posts**
