MGCP error
Jul 2nd, 2009
I have two fxs ports as mgcp gateways defined. The ports should be used as fax gateways. Now I have a problem with internal fax transmissions.
Does anyone know what this debug output means (Cisco 1760 router)
/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]Invalid parameter (pkt 0x850AA7B8 pkt->mgcp_parm_lines 0x
best regards
patrick
Overall Rating: 2.5 (2 ratings)
dsweeny Wed, 07/08/2009 - 16:07
This problem may be on Fax failures on inbound and outbound calls through PSTN GW. Remove MGCP PRE package and try. It may be also T1 issues.
