Marking DSCP on 3560
Jul 2nd, 2009
I am trying to use a policy map on a 3560 L2 interface for marking all traffic. Based on sniffer captures the config I have doesn't seem to be working. Any suggestions are greatly appreciated.
Many tkank's
following the configuration
mls qos
class-map match-any toto-visio
match any
policy-map toto-policy
class toto-visio
set dscp cs2
interface FastEthernet0/41
mls qos trust dscp
service-policy input toto-policy-visio
...#sh mls qos interface fa0/41
FastEthernet0/41
Attached policy-map for Ingress: toto-policy-visio
trust state: trust dscp
trust mode: trust dscp
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
...#sh policy-map interface
FastEthernet0/41
Service-policy input: toto-policy-visio
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Thu, 07/02/2009 - 04:00
Latest 3560 QoS configuration guide documentation doesn't list "match any". Didn't check command reference doc, although did look to see if "match any" (in configuration guide) documented as not supported, (which I didn't find it was).
From your config it appears you want to mark all traffic from that port's ingress as DSCP CS2, if so, you might not need an explicit class-map nor trust port DSCP.
Don't have a 3560 in front of me to test with at the moment, but see if this config is accepted:
class class-default
set dscp cs2
BTW:
This looks bad:
"class-map match-any toto-visio
match any
class toto-visio
set dscp cs2
mls qos trust dscp
service-policy input toto-policy-visio"
fernandezj Thu, 07/02/2009 - 06:08
Oups...
I Clean my configuration...but is not ok..
New configuration:
policy-map toto-policy-visio
class class-default
set ip dscp cs2
mls qos trust dscp
Thanks for your help
Edison Ortiz Thu, 07/02/2009 - 06:55
  • Hall of Fame,
    Founding Member
Jerome,
You don't need the 'mls qos trust dscp' on the interface if you are remarking every single packet entering the interface as CS2.
A trust is applied when you want to honor the DSCP marking from the directly connected device, not when you want to remark it per your example.
As for capturing the information, 'show mls qos int fx/x stat' will provide the information you need. On 35xx switches, the 'show policy-map interface' won't provide any hits.
In your case, you will see hits for DSCP 16 on switchports with 'mls qos trust dscp' enabled or with a service-policy (please understand the differences).
Per your example, you won't see hits against DSCP 16 on switchport F0/41 incoming as the packet is marked after entering the switchport but you will see hits against DSCP 16 on returning traffic.
Here is a little example:
R1 (f0/0)<-->(f0/1) SW1 (f0/15)<--> (f0/15) SW2
SW1 config:
mls qos
policy-map DSCP-16
class class-default
set dscp cs2
interface FastEthernet0/1
switchport access vlan 18
switchport mode access
service-policy input DSCP-16
interface FastEthernet0/15
mls qos trust dscp
Troubleshooting:
sh mls qos int f0/1 st | i 15 - 19
15 - 19 : 0 0 0 0 0
15 - 19 : 0 99929 0 0 0
sh mls qos int f0/15 st | i 15 - 19
15 - 19 : 0 100037 0 0 0
15 - 19 : 0 100039 0 0 0
HTH,
__
Edison.
