Router-in-a-stick inter-Vlan routing
Jul 2nd, 2009
I'm using a Cisco 1720 with 12.2(2) IOS
And the following command on the subinterface give an error:
encapsulation dot1q 1
Encapsulation command is available but with no parameters and it's not accepted alone.
Is there any way to so that?
Omar
mahmoodmkl Thu, 07/02/2009 - 06:00
  • Gold, 750 points or more
try with the native keyword and check.
Mahmood
omar.elmohri Thu, 07/02/2009 - 06:03
Once I use '?' the encapsulation exists but:
encapsulation ?
gives me that the command is incorrect.
omar.elmohri Thu, 07/02/2009 - 07:00
The only available RAM and Flash permitted me to go through 12.3(18)a
And the same problem I'm encountering.
lamav Thu, 07/02/2009 - 08:13
  • Blue, 1500 points or more
Hi:
You need the IP PLUS image at least to set encapsulation protocols on a 1720.
