FXS problem
Answered Question
Jul 2nd, 2009
I have a 2811 with VIC-4FXS/DID. I have an analog phone connected to port 0. When a call is coming and I pick up the analog phone, FIRST I hear some digits tones.
It means the if the analog phone is number 593, when I pick up the phone to answer a call I immediatly hear 5-9-3 digits tones and then I can talk.
here the configuration:
voice-port 0/0/0
dial-peer voice 593 pots
destination-pattern 593
no digit-strip
port 0/0/0
dial-peer voice 500 voip
destination-pattern 5..
session target ipv4:172.31.41.1
Does anyone have an idea on how to remove these 5-9-3 tones???
thanks in advance
Correct Answer by paolo bevilacqua about 7 years 10 months ago
It's because you have:
no digit-strip
remove that.
Overall Rating: 5 (1 ratings)
liettig Thu, 07/02/2009 - 21:40
in h323..
But I have the same problem with MGCP and also if I connect 2 analog phones to the 2811 FXS ports and I call from one analog phone to the other I have the same problem (also in h323 and MGCP)
Correct Answer
paolo bevilacqua Fri, 07/03/2009 - 00:37
  • Hall of Fame,
    Founding Member
no digit-strip
remove that.
liettig Fri, 07/03/2009 - 01:45
Thank you very very much!
Just one question about this topic..
by default "dial-peer pots" automatically strip any explicitly defined number (infact digit-strip is by default). So, why it works?.. If I define "destination-pattern 593" these are all explicitly defined numbers so the system should strip digits and the call fail.. but it works.. why?
thank you again!
paolo bevilacqua Fri, 07/03/2009 - 03:33
  • Hall of Fame,
    Founding Member
You're welcome, and thank you for the nice rating.
Digit strip logic occurs after the pots DP is matched via destination-pattern, that's why it works.
