Can VPN users change their own password via the VPN client?
Jul 2nd, 2009
hey guys,
quick question, how can I configure an 1841 router to make the VPN users to change their own passwords upon connecting to the network using the VPN client software?
insccisco Fri, 07/03/2009 - 05:20
are you sure? this has to be possible :(
I was looking into the commands and only found the login once command which only allows the username/password to login once to the network and then the credentials get deleted by the IOS...
that was a bit close to what I am looking for... so there has to be a way, perhaps using the Cisco AnyConnect?
I appreciate your help
