FWSM: Firewall between vlans
Jul 2nd, 2009
Customer has two core 6506 switches, and all VLANS are running HSRP between the core switches.
Customer is adding a FWSM to both core 6506 switches. They plan to 'firewall' traffic between the Voice and Data VLANS on both core switches.
How will I configure this in relation to running HSRP between the core switches?
Please advise.
Kureli Sankar Thu, 07/02/2009 - 10:15
  • Cisco Employee,
HSRP has nothing to do with configuring the FWSM.
In the route statements on the FWSM make sure to use the HSRP IP and not the physical IP.
Does this answer your question?
Jon Marshall Thu, 07/02/2009 - 11:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Colm
As Kureli says, the 2 are not really related. Bear in mind if you are firewalling between the voice and data vlans then you won't have L3 SVI's for these vlans on the 6500 switches anymore so HSRP for these vlans is not relevant.
The L3 interfaces for the voice and data vlans will have to be migrated to the FWSM.
Jon
colmgrier Thu, 07/02/2009 - 15:26
Thanks Jon & Kureli for the feed back.
As the FWSM will only being installed next week I'm just planning this install. I'm new to fwsms!!
Still quite confused about replacing HSRP running between the core switches, can you give me an example on how to configure this for the DATA & Voice VLANS on both fwsms. There must be full redundancy on both core switches.
Please see below for each core switch & fwsm.
### 6506 CoreA ###
vlan 10
name DATA
vlan 20
name Voice
vlan 30
name WLAN
vlan 100
name FWSM
firewall vlan-group 1 10,20,100
firewall module 1 vlan-group 1
interface Vlan 30
description "WLAN"
ip address 192.168.30.2 255.255.255.0
no ip redirects
standby 30 ip 192.168.30.1
standby 30 priority 105
standby 30 preempt
standby 30 authentication C1sc0
interface vlan 100
description "FWSM"
ip address 192.168.100.1 255.255.255.252
### FWSM CoreA ###
interface vlan 100
nameif outside
security-level 0
ip address 192.168.100.2 255.255.255.0
interface vlan 10
nameif DATA
security-level 100
ip address 192.168.10.1 255.255.255.0
interface vlan 20
nameif VOICE
security-level 100
ip address 192.168.20.1 255.255.255.0
route outside 0.0.0.0 0.0.0.0 192.168.100.1 1
### 6506 CoreB ###
vlan 10
name DATA
vlan 20
name Voice
vlan 30
name WLAN
vlan 100
name FWSM
interface Vlan 30
description "WLAN"
ip address 192.168.30.3 255.255.255.0
no ip redirects
standby 30 preempt
interface vlan 100
description "FWSM MGMT"
ip address 192.168.100.5 255.255.255.252
### FWSM CoreB ###
interface vlan 100
nameif outside
security-level 0
ip address 192.168.100.6 255.255.255.252
interface vlan 10
nameif DATA
security-level 100
interface vlan 20
nameif VOICE
security-level 100
route outside 0.0.0.0 0.0.0.0 192.168.100.5 1
Kind Regards,
Colm
Kureli Sankar Thu, 07/02/2009 - 17:40
  • Cisco Employee,
vlan 100 is the SVI (MSFC on the outside)
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/intro_f.html#wp1050361
The config looks pretty good for the first time.
So, this is inter chassis failover. Let us forget about chassis B FWSM for now and I will let you read the config guide here:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/fail_f.html#wp1142744
You need 1 or 2 vlans pushed down for failover interface failover state
There are two main issues in the config.
1. There is no access-list applied on the interface. To allow any traffic to enter the FWSM, you must attach an inbound access list to an interface; otherwise, the FWSM automatically drops all traffic that enters that interface.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/nwacc_f.html#wp1048418
2. Voice and Data vlan seem to have the same security so, you need this command in the config to be able to allow traffic between the two vlans.
same-security-traffic permit inter-interface
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/intfce_f.html#wp1059402
Good luck to you.
