NTP source interface
Tsasbrink
Did anyone of you ever notice that at this time it seems impossible to set the NTP source interface to a Loopback interface which is presistent ?
In software versions 12.4.24T and 24T1 the NTP source command is parsed before the loopback so it will tell you the loopback does not excist and hence will delete the line from the config ?
I did try to find this as a bug but came up with nothing.
TIA,
Tom
