QSIG segmentation for QSIG messages
Jul 2nd, 2009
Hi have a callmanager connected to cisco 3845 with mgcp, connected to other PBX with qsig gf, the other gateway is sending segments in the qsig messages but the cisco gateway is rejecting the segments. Is there any command to enable the the cisco gateway to accept the qsig segments .
paolo bevilacqua Thu, 07/02/2009 - 12:01
  • Hall of Fame,
    Founding Member
Cisco GW has no responsibility because you're using MGCP.
If you want a more robust QSIG solution, use H.323.
