Cisco Unified OS Administration Login
Answered Question
Jul 2nd, 2009
I am wondering if it is possible to change how to login to Cisco Unified OS Administration and Disaster Recovery System via the Web front end of Call Manager 6.1.3. Currently you need to login as Administrator to those 2 Web pages, but for Cisco Unified CM Administration, Serviceability, and Reporting you do not. I can login with my Call Manager account. It would be a lot easier if my and the other administrator could just use are Call Manager login for those 2 pages instead of the Administrator account. Is this possible?
Correct Answer by Jaime Valencia about 7 years 10 months ago
No, OS admin and DRS systems are separate from Admin pages.
You need to authenticate to each one because of what privileges each one provides within the system and at which level they're.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 07/02/2009 - 10:30
  • Cisco Employee,
  • Hall of Fame,
    2011
java
