How can I verify the total Unity ports
Answered Question
Jul 2nd, 2009
How can I verify the total of the Unity ports that we have in the system?
is the number unity ports equal to the numbers of VM calls that the system can handle?
Correct Answer by Jaime Valencia about 7 years 10 months ago
You can look at the GUSI.
1 VM port = 1 call (incoming or outgoing)
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 07/02/2009 - 12:17
  • Cisco Employee,
  • Hall of Fame,
    2011
java
