Cisco VPN Client with RVS4000 router
Jul 2nd, 2009
Can I use the Cisco VPN client with the RVS 4000 router instead of the QuickVPN client?  I read a post on another forum that the QuickVPN client will not work with another vpn client installed on the computer.  I have to use the Cisco VPN client to access files at work and client locations.  I also want to access my windows shares on a samba server located on my home network.  The RVS 4000 is the router for my home network.
Te-Kai Liu Fri, 07/03/2009 - 00:33
  • Gold, 750 points or more
Some folks can have both clients installed and use one of them at a time. Why not giving it a try?
lfmoreno07 Mon, 09/13/2010 - 10:19
I know it's been a while since your post,
but where you able to use the Cisco VPn client for this?
I am in a similar situation as you were.  What did you end up using?
riroe Mon, 09/20/2010 - 03:06
The Cisco VPN Client cannot be used with the RVS4000. Only the QVPN client can be used. The Cisco VPN client is not compatible
with the RVS4000.
THANKS
Related Content
