drolemc Wed, 07/08/2009 - 05:43
  • Silver, 250 points or more
The MSFC shows high CPU utilization and the process is SCP async. SCP is the out of band protocol used for communication among Sup module and the rest of the cards in the chassis including the MSFC daughter card.
Therefore, the action plan would be to check that modules are properly seated in the chassis; check and reset them if required.
And check for any pin or notable damage.
