Want to upgrde LMS from 3.0 to 3.1
Jul 2nd, 2009
Hi Team
Plse let me knoe is 3.1 available on cisco for download or we need DVD of 3.1 to upgrade LMS from 3.0 to 3.1
We have to take new license for 3.1 or we can use 3.0 license with it.
if possible to download, plse provide the link.
Vaibhav
Lucien Avramov Fri, 07/03/2009 - 17:35
  • Red, 2250 points or more
Check the Cisco Product Upgrade tool at www.cisco.com/upgrade to determine if you are entitled to any major or minor version updates of your current LMS product.
If your contract permits, I suggest you to look at LMS 3.2 which is the latest release.
mattoxm.psrc Mon, 07/20/2009 - 09:32
The upgrade for 3.2 can be found but it is tricky. It is actually a download for the trial version of 3.2 and it recognizes the license currently in use and does the upgrade.
