CCME problem
Jul 2nd, 2009
My company has an E1 telephony line conected to a CCME(3845).
We have 99 phone numbers, from xyz00 to xyz99
When i call from the inside out from any extension, it always shows me the firs number on the outside phone(xyz00).
The provider told me that its a configuration problem on the CCME.
Here is the conf:
voice translation-rule 1
rule 1 /^03xyz\(8..\)/ /\1/
voice translation-profile VM
translate calling 1
translate called 1
translate redirect-called 1
controller E1 0/0/0
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
dial-peer cor custom
name RDS
name RTc
name Vodafone
name International
dial-peer cor list RDS
member RDS
dial-peer cor list RTc
member RTc
dial-peer cor list Vodafone
member Vodafone
dial-peer cor list International
member International
dial-peer cor list ResNoIntl
member RDS
member RTc
member Vodafone
dial-peer cor list ResRDSVodafOnly
member RDS
member Vodafone
dial-peer cor list Unrestict
member RDS
member RTc
member Vodafone
dial-peer voice 1 pots
corlist incoming Unrestict
incoming called-number .
direct-inward-dial
dial-peer voice 12 pots
corlist outgoing RTc
destination-pattern 02........$
port 0/0/0:15
forward-digits all
dial-peer voice 13 pots
corlist outgoing RDS
destination-pattern 03........$
port 0/0/0:15
forward-digits all
dial-peer voice 14 pots
corlist outgoing Vodafone
destination-pattern 072.......$
port 0/0/0:15
forward-digits all
dial-peer voice 17 pots
corlist outgoing International
destination-pattern 00.T
port 0/0/0:15
forward-digits all
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000301
max-ephones 100
max-dn 100 no-reg
ip source-address 10.47.128.9 port 2000
url services http://10.47.128.8/voiceview/common/login.do
url authentication http://10.47.128.8/voiceview/authentication/authenticate.do
time-zone 28
time-format 24
dialplan-pattern 1 03xyzvab.. extension-length 3
voicemail 888
max-conferences 12 gain -6
call-forward pattern .T
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Mar 27 2008 09:52:38
ephone-dn 1 dual-line
number 810 no-reg primary
call-forward busy 888
call-forward noan 888 timeout 30
ephone-dn 2 dual-line
number 811 no-reg primary
ephone 1
no multicast-moh
mac-address 001B.2AC7.4FC8
username "user810" password cisco
type 7941
button 1:1
ephone 2
no multicast-moh
mac-address 001B.5484.96CD
username "user811" password null
type 7911
button 1:2
Why doesen't the CCME send all the extension numbers to the provider?
Thank you,
Laszlo
Overall Rating: 4 (1 ratings)
paolo bevilacqua Fri, 07/03/2009 - 00:35
  • Hall of Fame,
    Founding Member
When you use dialplan-pattern, that changes the numbers sent and received to PSTN>
I recommend to not use it, and use translation-profile and rule instead.
buchholr Sun, 07/05/2009 - 06:40
I don't see anything in your config that would cause the CCME to overwrite the Caller ID. I recommend you do a "debug isdn q931" and capture the output when making a call from different extensions. It is common for carriers to overwrite caller id with the billing number. And, in true carrier fashion, they will always say it is in your system first, before checking theirs.
The output from the debug will show the information that the router is handing out the isdn data link. I suspect that you are sending the correct digits, but they are overwriting them.
Hope this helps,
Rob
