Wireless Roaming & Max connection on WAP54GP
Glenn Quesenberry Fri, 07/24/2009 - 13:49
  • Cisco Employee,
You can't do "seamless" roaming with these APs as they are controller-less.  However what you could do is set the same SSID on each AP and manually configure the channel that each uses instead of auto.  This will still require the client devices to reauthenticate however to each AP they connect to, so not good for Real Time traffic but usually ok for typical data.  Another option with these APs is for you to set them up in reapeater mode if possible and have one act as the "main" AP and allow it's signal to be repeated to the others as long as they could all "see" each other wireless signal.  As far as number of clients this AP supports up to 32 client devices.
Best Regards,
