Unity Connection IMAP
Jul 3rd, 2009
Hi guys,
just wanted to run this by some of you if you can think of any gotchya's :
we have a customer that has both a Domino (AD1)and an Exchange(AD2) environment (there's been a merger) - they will have seperate Call Manager clusters that will be integrated to the same Unity Connection cluster. They will need both Client IMAP connections from Outlook and Lotus Notes (should'nt be an issue) but they will also want TTS (not sure if they can have that from the 2 locations, Exchange and Domino?).
The other possible show stopper is that we have pointed Unity connection to get its users from CUCM which is LDAP connected to AD1 and therefore I cannot see how we can get the users in from AD2?? Any advise would be appreciated...cheers Jag
Overall Rating: 3 (1 ratings)
askq2forum Fri, 07/03/2009 - 01:34
Just an update, the TTS to Domino is not supported , so I think its the AD integration that's the issue...cheers, Jag.
James Hawkins Fri, 07/03/2009 - 02:57
  • Gold, 750 points or more
Hi Jag,
I think you could point CUCM at two separate AD's for synchronisation purposes without any trouble as long as you use the same AD attributes to map to CUCM for both directories.
The problem would come if you want to set up LDAP authentication as that only seems to allow you to point at one LDAP directory. I am no AD expert but would imagine that it may be possible to authenticate between two ADs.
askq2forum Fri, 07/03/2009 - 04:47
James,
thanks for the reply, yes we have come to the same conclusiion, LDAP sync is ok but ldap authentication between trusts I'm not sure about - at this stage to be truthful I don't have full details of the AD infrastructure whether they are completely standalone or not...Thanks,Jag
