ASA Clientless SSL - ActiveX Relay
Jul 3rd, 2009
I would like to know if it's possible after a user has loggued in the WebVPN Portal to restrict his access to only the portal. For example if the user open a new tab or new window and try to access google.com, it's not working.
Any ideas?
With the Activex maybe?
umedryk Thu, 07/09/2009 - 12:17
The Management Portal comes with a number of groups and roles predefined. To give a user administrator privileges over your entire system, for example, it is only necessary to assign them to the Administrators group. The following table shows what groups are supplied with the system, what folders they can access, and what roles they can perform on those folders. The tasks that make up each of the roles are also listed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/cisco_management_portal/cmp7_1/user/guide/mp713ug.pdf
