LMS 3.0 Campus Manager Report Export
Jul 3rd, 2009
I am using Cisco LMS3.0 running on solaris 10, I need to know where I can find report in the cvs format which I have exported from the Campus Manager. I don't know the path where these reports are save in the server.
Lucien Avramov Fri, 07/03/2009 - 17:18
  • Red, 2250 points or more
The csv file is pushed to the client computer from the server's GUI. The file is generated on the fly and it seems not to be saved on the server under a csv file.
hashmatpaki Fri, 07/03/2009 - 21:03
I have exported CSV file many times but I did not find any CSV file in my PC where as when I export a pdf file it opens in a web page, actually I need CSV file so that I can edit it.
Lucien Avramov Fri, 07/03/2009 - 23:56
By default the file is called export.csv when you export it.
Try searching for this file on your PC.
