Rauge Ap Problem
Jul 3rd, 2009
Hi Team,
I am having 10 Lwap with 4404 controller in my site.I am facing problem with rauge ap's.I am not able to connect to my network.There are 100 rauge ap near my site....i think my controller is not able to provide channel to my ap's.Please suggest what to do with this case?
Satya.M
Lucien Avramov Fri, 07/03/2009 - 18:31
  • Red, 2250 points or more
in most of the cases rogue ap's do use the 2.4 GHz frequency, try to configure yours on the 5.0 GHz and see if that helps
satyamothukuri Tue, 07/07/2009 - 04:51
please find the run-config ....please help me in this case....
Satya.M
Leo Laohoo Fri, 07/03/2009 - 19:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I don't understand this. The WLC has Dynamic Channel Assignment enabled by default so you shouldn't be making any changes.
WHY are you not able to connect?
WHAT are the alarms on the WLC logs?
Leo Laohoo Tue, 07/07/2009 - 14:28
  • Hall of Fame,
    2017 LAN, Wireless
Have the following questions:
1. Have you checked your Emergency Image Version? It says "Error". Not a good sign.
2. What's going on with your Contoller Configured Country? You have "Multiple Countries:MX,AT,IN,HK,NZ,PA,DO,CA,PH,AR,PE". Nail this down to your country FIRST because this could be causing your problem.
satyamothukuri Wed, 07/08/2009 - 20:09
thanks for your reply....
but my problem is some thing different....my controller is not able to set the channels becouse the rauge ap's are also having same chennels....as i told you there are 100 rauge ap in my location....Please help in this case....
Satya.M
Leo Laohoo Wed, 07/08/2009 - 22:32
  • Hall of Fame,
    2017 LAN, Wireless
Hi Satya,
You are confusing me. In your first post, you entered "I am not able to connect to my network". Now, you are saying "my controller is not able to set the channels becouse the rauge ap's are also having same chennels".
Can you please specify which of the two is your problem?
satyamothukuri Thu, 07/09/2009 - 23:02
Thanks for the reply.My only problem is access point not able to get channel from controller becouse of rouge ap's.If my ap is not getting Channel how my clients get connected?This is a link from one one.Please find the debugs and run config.....
Satya.M
Leo Laohoo Sat, 07/11/2009 - 05:11
  • Hall of Fame,
    2017 LAN, Wireless
Y'know what? I think we got off the wrong foot here.
Have you tried to set your WLC with NO Authentication and see if your clients are able to successfully Associate/Authenticate?
If not, I recommend you try it.
When your clients are able to Associate/Authenticate successfully using OPEN Authentication, you can start piling up the security stuffs.
Let me know if you have any more questions.
Trending Topics - Security & Network
