Noob InterVLAN routing Question
Answered Question
Jul 3rd, 2009
Hello All,
If I have several VLANS configured on Layer 2 switches, a firewall in front on the network and then a router in fron of the firewall how do I then get routing going in between VLANS? The firewall is doing natting at present. Thanks in advance. All replies rated!
Correct Answer by Jon Marshall about 7 years 10 months ago
Angel
So does your network look like
2950 -> firewall -> router
If so you can either
1) run the firewall in transparent mode and route the vlans off the router
2) route the vlans off the firewall
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 07/03/2009 - 05:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Angel
Jon
