sbilgi Thu, 07/09/2009 - 06:08
  • Silver, 250 points or more
Try this to solve the timeout problem
Click on start ---- programs ---- administrative tools ---- internet services manager
------ expand on cm icon ----- Right click on Default Web site option -------- click on
properties ----- select web site option from the properties above ------ In the connection
timeout box change the value from default 900 seconds (15 minutes ) to the number of
seconds of your choice. Now restart IIS service.
pwenger Thu, 07/09/2009 - 22:46
It's CUCM 7.x, so there is no Microsoft Windows anymore!
Peter
Jaime Valencia Wed, 09/23/2009 - 05:19
  • Cisco Employee,
  • Hall of Fame,
    2011
There is no way to change this
CSCsj45520
CM 6.0/7.0 Customer should be able to configure/disable CCMAdmin timeout
This has been asked plenty of times before, PLEASE search NetPro for answers.
java
if this helps, please rate
ttortelier Fri, 01/07/2011 - 07:02
He was talking about CCM User page.
Can you confirm it is the same issue for this part?
thanks,
Thomas
ttortelier Fri, 01/07/2011 - 07:17
Ok thanks,
The using of webdialer was really boring, and will remain the same
Bye,
Thomas
