trunk connection
bobita2604
I have a server that shared the ethernet port for the NIC and the IPMI. I want to associate a vlan (10) to IPMI and use the native vlan 1 for the NIC. I use a 2960G switch, the ports are configured in mode trunk and nonegotiate.
The IPMI configured in the vlan 10 not respond (arp, ping). Moreover, if I replace the cisco switch with a non manageable switch everything works OK. What is wrong in this trunking configuration?
Liana
eswu0c0#sh interfaces gigabitEthernet 0/10 status
Port Name Status Vlan Duplex Speed Type
Gi0/10 connected trunk a-full a-1000 10/100/1000BaseTX
eswu0c0#sh interfaces gigabitEthernet 0/12 status
Gi0/12 connected trunk a-full a-1000 10/100/1000BaseTX
eswu0c0#sh interfaces gigabitEthernet 0/10 trunk
Port Mode Encapsulation Status Native vlan
Gi0/10 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/10 1-4094
Port Vlans allowed and active in management domain
Gi0/10 1,5,10
Port Vlans in spanning tree forwarding state and not pruned
Gi0/10 1,5,10
eswu0c0#sh interfaces gigabitEthernet 0/12 trunk
Gi0/12 on 802.1q trunking 1
Gi0/12 1-4094
Gi0/12 1,5,10
Gi0/12 1,5,10
eswu0c0#sh running-config
Building configuration...
Current configuration : 3012 bytes
! Last configuration change at 13:31:41 UTC Fri Jul 3 2009
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname eswu0c0
no aaa new-model
vtp mode transparent
ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
vlan 5
vlan 10
interface GigabitEthernet0/10
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet0/12
dan_track
You haven't defined the encapsulation on interface GigabitEthernet0/10 , unless the switch automatically is set to a trunking encapsulation e.g dot1q.
Dan
Hi Dan,
In 2960 series only dot1q is supported so the "switchport trunk encapsulation dot1q" command is not supported.
Leo Laohoo
Why is the switchport configured as a Trunk instead of a switchport access vlan 10?
I want to use the native vlan 1 for the ethernet interface of the server (the IPMI and NIC are connected on the same switch port). Moreover, the IPMI is already configured in vlan 10.
