DNS rewrite
Jul 3rd, 2009
I have a 5520 failover pair running 8.0(4). There are physical interfaces connected to inside and outside, two DMZ logical interfaces and a logical interface to a services network.
There is a static translation from outside to a DMZ-I host...
static (DMZ-I,outside) externaladdress dmzaddress dns
The global policy is enabled on all interfaces with DNS inspection. Our DNS servers of parent organisation are located on our services link.
If I query a dns server located on the outside(internet) I get a dns rewrite response with the DMZ-I address.
When I query DNS servers on our services link the response is not rewritten.
Is this expected behaviour as the static is on a different interface to the DNS response?
If so is there a workaround?
Thanks for your help
Kureli Sankar Fri, 07/03/2009 - 07:00
  • Cisco Employee,
Your observation is correct. Works as expected or breaks as expected.
You can use destination nat to get around that.
static (dmz,inside) public-ip dmz-1
This will let the inside host access the dmz1 host using public IP address.
lech_2000 Fri, 07/03/2009 - 07:46
thanks for you reply Kusankar, this is further complicated by our proxy server sharing a DMZ address with some sites.
I created a static between the services net and the dmz which is enabling the dns replies to be translated..
static (DMZ-I,SERVICES) externaladdress internaladdress dns
thanks again for your help
