CME Live Recording Working but get a "Live Record has Stopped" message
Jaime Valencia Fri, 07/03/2009 - 11:36
  • Cisco Employee,
  • Hall of Fame,
    2011
You might be hitting this bug:
CSCsq79034
Wrong Display while using LiveRcd softkey
Symptom:
If the call is active between phone A and phone B and phone A presses
the softkey LiveRcd , then the call is recorded however the display
says " Live Record has stopped" which is mis-leading to the users as
they feel the call is not recording but it actually is recording and
phone A gets a message after the call is disconnected.
Conditions:
its a cosmetic bug
Workaround:
Now if the call is active beween phone A and phone B and phone A presses
conference softkey and dials 9200 and presses conference softkey again ,
the call is recorded and phone A gets a message
java
if this helps, please rate
