Switch configuration change & VTP
Jul 3rd, 2009
I intend to change some configuration of oneof Coreswitch (6500) which is the standby member from HSRPgroup.
My concern is, if i change it in running powered mode, will this be affected by vtp client overwrite & other vtp issues.
Should i remove the uplink connections, configure the switch & then power it up?
Even then , would it be overwritten by other client ( edge switch ) configuration somehow during power on.
Or should i power on back after changing the mode to transparent & later put it back to client & server.
Please help to clear this confusion
Thanks.
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Sun, 07/05/2009 - 11:40
Hello Sunny,
if you change the VTP domain name and/or use VTP mode transparent the switch retains the current vlan database and beco mes indipendent from the others.
If you then reverts back to the original VTP domain name and a vtp mode client or server the vlan database will be updated by the others.
However, I didn't understand what is the change you would like to do: it is a good idea to explain what exactly you want to do: HSRP is a L3 feature and any change to it is not related to VTP that is a signalling protocol at OSI L2.
Hope to help
Giuseppe
