SRST over CCME
Jul 3rd, 2009
Hi NetPro
I can use or configure a gateway whit SRST using a CCME whit call control?
I have a two site one whit 200 user ideal for use CCME, the other site have 20 user.
My ideal is configure CCME whit one call control and gateway whit SRST working whit CCME.
Regards.
Overall Rating: 4 (1 ratings)
jmecklenburg Fri, 07/03/2009 - 08:42
Sorry my English is very bad. :D
In this paper the CUCM is the call control and CCME SRST Fallback use when the uplink to CUCM fail.
In this case think a CUCME like call controll and another gateway whit SRST working on CUCME.
it's posible
Rob Huffman Fri, 07/03/2009 - 09:16
Hi Javier,
The SRST relationship is built between a CUCM deployment and a SRST Router. There is not a similar deployment relationship available between two CUCME setups.
Hope this helps!
Rob
