Client VPN for RV082 on Vista
Jul 3rd, 2009
I have an RV082 router and have been using the Client VPN on my XP computer.  I just updated the OS to Vista and the Client VPN no longer works.  Could you send me a link to the download so I can have a working Client VPN?
daviddun Fri, 07/03/2009 - 10:57
  • Bronze, 100 points or more
Good Afternoon Ralph,
If the quick VPN client is not working, then I would recommend you try to download the newest version of it from the www.cisco.com/smallbusiness website.  Just find your RV082 software and download the newest firmware for the router and the quick VPN client.
Hope this fixes your issue.
ralphbrodriguez Fri, 07/03/2009 - 16:13
I updated my Client VPN and it almost worked.  It locked-up at the network verification.  I then updated the firmware of the router and now all is well! :)
