07-03-2009 11:18 AM - edited 03-04-2019 05:19 AM
I have tried to enter the "no ip http server" command and the "no ip http secure-server" commands and I still see http connection is enabled on the router, see below:
HTTP Client Connections:
Persistent connection = enabled
Initial socket connection timeout = 5 secs (default)
Connection idle timeout = 2 secs (default)
Total HTTP server connections = 0
Can anyone provide feedback on how to disable http access on the router?
Please let me know!
Thank you.
Rgds,
Vicky
07-03-2009 11:29 AM
Try connecting. Display output may be irrelevant.
07-03-2009 11:31 AM
Vicky,
You did the right things. (grin) If you want to check it please use a "show ip http server all" command. You will see some thing like this HTTP server status: Disabled.
HTH,
Toshi
07-03-2009 04:06 PM
This was the confirmation I needed. Thank you so much!
07-03-2009 11:31 AM
Hello Vicky,
Have you tried to access the router admin page?
Is it still reachable or not ?
if not the show command provides parameters for http client connections but it is a different matter.
Another note is about SDM:
have you used SDM on it?
This could need additional / different commands to disable http/https access
Hope to help
Giuseppe
07-03-2009 11:33 AM
Hi Guys,
Vicky typed a "sh ip http client" command. That won't tell you what you want.
HTH,
Toshi
07-03-2009 04:07 PM
Hi Giuseppe,
I gave this a try and the router was un-reachable. Thank you for your help!
Rgds,
Vicky
07-05-2009 02:31 PM
no ip http server and no ip http secure-server are enough to disable http on the router.
If you still have doubts, you may want to apply an ACL that matches http traffic and log it. That will proove you that http is no longer working once the above commands are entered.
